Hello all,
Brand new to the group....just picked up my LMTV a couple days ago and have been just kinda going through it. Few issues need addressed.
The first and most important is the transmission is slow to shift. The engine spools fine, but the trans just doesn't seem to want to upshift. It will eventually....but not when it should.
The only code on the trans controller is 1323. I cleared the code via the controller and no change. Trans appears to have transmission fluid in it, not engine oil.
As a test, I shifted manually. Started in 2nd....revved the engine to max rpm, and up shifted. Shifted firm and immediately. It did so for every gear. Do these trucks have a TPS (Throttle position sensor)? Forgive the possibly dumb question....brand new to trucks this large.
Regards,
Jason
Rhome, TX
Regards,
Jason
Rhome, TX
