Small fuel tank for off-roading
cranetruck
94
Meadows of Dan, Virginia
Operating off road on steep slopes with a low level of fuel will cause the in-tank pump to suck air on occasion and the engine will not idle nor start normally. With the dual tank system I'm able to transfer the fuel to the smaller tank and thus increase the fuel level....just passing on, to me at least useful info...
spicergear
29
Millerstown, PA
Good thoughts- Nice control panel. Bjorn, if you build another truck you could maybe just start with a Cessna aviation control panel so all the switches and light would be there already :)
gene
Northern Idaho
Bjorn, I must say that you are an artist with the trucks you work on. Not trying to blow sunshine up yer 6 but the work you do is top notch. You are an asset to this site.
Gene
