Smittybilt seat installation???
davik
Ventura Ca
SO I got my seats in but my seat bases have no covers or brackets. Does anyone have a good source where I could get those?
LouWon
94
Michigan
I used these on the drivers side, from E-bay
The front passenger side is bolted to the cover
TDButler
11
NJ
For my driver seat, I mounted on a Sentry Safe electronic lock box. Square steel box, stronger than factory and fit pretty close to perfect. I can't figure out how to post pictures from the mobile, but the SentrySafe is about 8"H x 16"W x 14"D, worked with my smittybilt and gives a much needed place to lock up belongings.
badgerd
Electronic Jedi
104
65
Chesapeake VA
That’s a great idea. How did your seats fit with the 3 point belts? Can’t get the passenger side to fit back far enough without removing the belt tensioner...
Way more than “just bolt them in” that I read in some other threads...
Sent from my iPad using Tapatalk
TDButler
11
NJ
I had to "persuade" them a bit. But they did eventually go in fine. There's a little give to the back cushion on these seats you just have to give it some wear-in. Now that they are in, they don't impede my seat belts at all. But then again, there may be some manufacturing differences from one unit to another
LouWon
94
Michigan
It's an aluminium cover, just get some flat stock from HD or someone else to reinforce the bolts, you should be good
