Snow plow mount
sreng
57
13
WY, USA
I am looking for some photos on how people have built mounts for a snow plow (13') . The bumper/frame rail area is fairly easy. Mainly looking for examples of the lower mounting points. I only found one example searching. Thanks in advance.
davidb56
1,237
Bonners Ferry Idaho
if you're using the frame already, where else is there to mount to? Ive seen one lower mount to the front differential/axle, which would have to allow for a lot of movement, and one that went under the axle to a spot farther back on the frame, but that decreased the clearance quite a bit.
