TurboTim
- 0
- 0
- Minneapolis Minnesota
I have harrowed it to not be the ram but the rod that controls the ram. The reason I can say the ram is good is I have no leaks when I blow air into each side with compressed air. It almost will fully turn the wheels doing that but it wont. So I have the other usit off that runs from the pitman arm and I am trying to figure out how to take it apart. There doenst seeem to be much movement anywhere and the one rubber gasket that I took off has a tear in it. I also cant really pull any other peices off? There is a 3/8 allen on the bottom that I can not even remove with heat or at least dont want to heat it anymore. Kinda just dont know where to go from here?
