kapnklug
- 2
- 18
- spencer,ny
...for $615, it's off a '93 6.5 and seems pretty complete (I've included the description that came with it at the bottom of this post). I've read T_F_E's excellent turbo-install thread, but I still have a few questions maybe you guys could help me with (it's going on a '86 M1009 with 40k miles):
1. What should my boost pressure be, like 10P PSI? Is the mechanical waste gate adjustable? Where's the best place to tap into the intake for the boost gauge tubing (maybe there's a port made for this?)
2. I'll be installing a pyrometer. Where should I weld in the bung for the thermocouple -- just past the driver's exhaust manifold, or in the downpipe after the turbo? Max exhaust temp is what, around 1100deg?
3. I'll be turning up the fuel delivery in the IP. While the top of the engine is apart, should I also install 6.5 marine injectors? Cost is a factor here, but so is the labor of taking it all apart again if I change my mind. I'm already using a Walbro FRB-22 electric fuel pump and pre-filter near the tank.
4. Does anyone make a 4" exhaust kit for the rest of the single exhaust?
Will the crossover pipe from the '93 work on the '85, with a 3" lift?
5. I guess I'll have to move one or both batteries to clear the turbo and airbox?
Any other suggestions/concerns would be appreciated. Here's the original Ebay description:
Here is a Complete Turbo install kit to convert a Non-Turbo 6.2 or 6.5 to Turbo, I will list each item and P/N's. Some pn's maybe old, I got the P/N from
compnine.com. The parts all came from a 1993 GM 6.5 Turbo Diesel, Block code J, I have mutiple other parts available!
The Gm-3 turbo is not rebuilt and does not need to but but I can if that is what you want (150.00) rebuilding charge!
Intake: Turbo: Exhaust:
12556527 Lower Intake Man. 10226226 GM-3 Borg-Warner Turbo 10191474 Exhaust cross over pipe
10226227 Upper Intake w/o Sensor no P/N 90 degree turbo to exhaust 12557359 Exh manifold LH
10154653 Hose and clamps Up. Int. to Turbo. 10223559 Turbo heat shield 12556476 Exh manifold RH
no P/N Upper Intake Cover (Turbo Power) 10222297 Turbo brace to intake No P/N (2) Heat Shields for RH Exh.
25098524 Air filter Box w/o filter 10222296 Turbo brace to intake No P/N (2) Heat shields for RH glow plugs
10154603 CDR hose to Turbo duct 12563904 Turbo Oil return tube/hose No P/N (1) RH valve Cover
25098706 CDR valve 10149659 Turbo oil ret. plate to engine No P/N (1) Turbo exhaust downpipe w/clamp
10154654 CDR Valve and tube to turbo 12562378 Turbo oil Supply hose No P/N (Oil fill tube)
25170522 90 degree Duct Air Filt. to turbo No P/N RH bracket on Valve Cover supports the upper heat shield.
Included with the parts is bags of almost every bolt needed to Install the kit . The Turbo turns freely and waste gate is also fuctional.
The bolts are separated by groups Intake, Exhaust, oil drain plate to the block
You would need: intake gaskets, exhaust gaskets, turbo to manifold gasket, turbo oit drain gasket , exhaust manifold seals,.
