Solargizer help for MEP-003A?
EnteJager
NJ
So I noticed the battery setup on my newly acquired MEP-003 is not the same as my M1009 CUCV. I figured that since it was going to be 24 volts it would have the same in series type setup as the CUCV.
I would like to add a solargizer to the batteries, do I need a 12 volt for each battery? or am I missing something, I counted 2 positive and 2 ground cables
that connect to the batteries, doesn't look like a series setup. How does it get the 24 volts?
Thaanks
DD
Nonotagain
41
Parkville, MD
Your MEP-003 should have a hot + coming from battery #1 going to the starter. The ground - from battery #1 and the hot + from battery #2 should be hooked together and then finally a ground - from battery #2 should go to the generator ground.
If the batteries are wired any other way you have a 12 volt system.
EnteJager
NJ
Thanks,
I just went back outside for another look. The unit was in storage and they had the small cable for the series connection taped to the +pos going to the starter, kinda gave a visual illusion. :oops: Thought I was missing something.
On a different note, the unit came with 2 brand new 6TL's that haven't been put in service (dry). I don't know how old the batteries are, do you think it is worth spending the money on electrolyte , or should I just buy 2 new maint. free.
Thanks,
DD
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
The acid is way cheap. spend the money and charge them fully. If they were dry and never had acid in them they should be fine.
Isaac-1
50
SW, Louisiana
I had a dry battery filled and charged at the local battery shop for $10, which was cheap enough for me to not worry about doing it all myself. As to the solargizer, you have a 24 volt system so you will want a 24 volt solar charger, trying to charge with a pair of 12 volt solar chargers is just asking for potential trouble with things like unbalanced charging (one panel may be in the shade more, etc.).
Ike
EnteJager
NJ
Thanks for all the replies, I have a 24 volt solargizer on my CUCV and just ordered more for the gen and the M35A2.
I was alittle confused by the way they had the battery cables tie wrapped, no batteries installed, looked like 2 +pos and 2 -neg cables running up inside.
Once I cut the tie the short cable for the series connection dropped and life was in focus again. I think they call it a brain fart.:-D
Thanks again
Dave
