Solargizer/Pulsetech mounting on 1151
rcamacho
818
Bainbridge Island Wa
I have a solar pulse charger that is known good. Curious about standard mounting locations in the service. I’m not overly enamored with hood/mushroom cap mounting or drilling holes in the top. Considering fabricating an aluminum panel mount to an existing location near the RF passenger roof for instance
papakb
1,183
San Jose, Ca
I mounted mine in the center of the hood between the radiator opening and the windshield thinking the curious can see it but they can't touch it. I mounted it with wellnuts to simplify the mounting and to add a little vibration protection to it. The wiring I ran down inside the channels on the bottom of the hood by drilling 2 small holes and routing the wires down to the hood hinge and then along the frame back to the battery box.
  • Like
Reactions: OBX
papakb
1,183
San Jose, Ca
The only thing that needs to be close to the batteries is the converter box that provides the high voltage spikes to keep the batteries from sulfating. The solar panel itself can be anywhere and comes with about 15 feet of wire.
Hummer Guy
800
United States Louisiana
Don't know if you got a hard top, but you can always use double sided tape and mount it on top instead of drilling it in if you got a hard top
kendelrio
8,579
Alexandria, La
I didn't hard mount mine. I used non reversible connectors to make it to where I could disconnect the panel , mounted the box behind my seat (I have a 5 ton) and stow the charger while I'm driving and set it up wither on my roof or hood when parked to charge the batteries.
kendelrio
8,579
Alexandria, La
Here's what I did bud, I knew I had pics... 🤦‍♂️
The non reversible connectors so I didn't hook them up backward:
Mounted the box just outside of my battery box:
And I can deploy the solar panel when convenient and store when not in use to minimize risk of damage:
