Barrman
- 1,730
- 113
- Giddings, Texas
I know, the solid state blinker box is supposed to go on the drivers side inner fender on the M35.
I do not know what year the blinkers were switched to the solid state system. I also don't know what year the alternator replaced the generator/external regulator. Based on what I know from my M715, I would guess mid to late '60's.
My Gasser never had blinkers, but it had a generator with the firewall mounted regulator. I have swapped in an alternator which leaves those 4 regulator mount bolts holes on the firewall empty. I was looking for a place to put the solid state blinker box since I don't have any fenders on the truck yet. I just happened to hold the box up to the regulator mounts and they are perfectly spaced.
Though some of you that have the box flopping around on the inner fender on trucks with the regulator mount holes on the firewall might want to think about moving it away from the muck.
Now that I have it installed, I need to get another since the only thing that works is the indicator light on the blinker switch lights up steady. But, that is another thread.
