Some sorta leak
TGeorge
60
Gardnerville, NV
M1078 A1 circa 2006 I have something leaking, either Hydraulic fluid or diesel that is leaving a light coating on the top of my fuel tank. I first I thought is was my cab tilt pump as it was a bit "wet" and a known failure point, but after pulling off the pump mount cover plate I don't think so. The oil at the pump is probably just the aerosol that escapes at the sintered vent. Lines to the pump were not wet.
I pulled the rock guard off the front of the fuel tank and there is a maze of hoses on top of the tank (fuel lines) and a 2nd maze of hydraulic lines connected to the hydraulic control / selector panel.
I de-greased and pressure washed the area as best I could. This may help me locate the leak, but I was hoping that others have been down this road before. Love to hear about what they found.
flyfishtrailer
1,019
Cool, CA
The internal seals on the hydraulic pump are notorious for going out. If you're seeing spray coming out the vent, they need to be replaced. Mine started with the spray leak but very quickly became full on liquid squirts. You may also have leaky valves in the control box. They are not hard to replace, but if you're going to do one, you may as well do all of them. Only other thought would be the fuel lines.
TGeorge
60
Gardnerville, NV
I have the rebuild kit for the pump, but I expected to find a leak running down the hoses from the pump to the top of the fuel. The pump hoes were dry.
Thanks for the info about the control box. Anyone have the PN# and source for the seals / orings for those control valves?
