Something rattling in my head
pcstan
63376, Missouri
I just acquired my 2nd M1123, and after cleaning up the fuel system and starting the engine for the first time I'm hearing a rattling or clunking sound coming from one of the heads.
I'm a competent mechanic but I've never worked on a diesel before. I'm thinking about just hauling it to a shop and throwing money at the problem, but I really don't want to. Should I bite the bullet and start wrenching?
What would you do in this situation? How difficult/easy are these 6.5's to work on?
Thanks in advance!
spankybear
897
WA
This maybe the "normal" 6.5 sound. When they run I think I hear a pinging or knocking or clunking noise. If you know anyone in you AO with a 6.5 in your area would listen to it and compare. I have also found that these engines seem to have their own personalty to say. One will be a dog, one will run like a race horse and others like someone just woken up. This is my experience.
spankybear
897
WA
As how hard are these engine to work on? Guess that would depend your you and how well you use tools. I do not find them hard. However if yours has one of the dang 400 amp alternators... that would make a nun cuss like a sailor.
Mogman
9,528
Papalote, TX
Welcome to the SS forums, try cracking each injector line loose one at a time on that side of the engine and see if you can narrow it down to one cylinder.
And as Spankybear says some just have a life of their own.
