jimm1009
- 71
- 48
- Louisville, KY
What you more experienced owners think about pulling the differentials on a new-to-me truck.
I know that is has been decommissioned since November of 2007 and sitting outside of course. Is there any advantage to pulling the differentials out for a good looking over?
Could this perhaps prevent any problems down the road that I'm not aware of?
I do have the shop and the tools and the TMs and so forth.
I know that a lot of time you don't want to fix it if it isn't broken but these are probably very expensive to rebuild so just wondering if any PM could or should be done other than the usual pinion seals and other related axles seals, bearings, and brakes which I will do any way.
** On a side note, I am looking to buy a couple of torque wrenches that will be needed down the road. Seem to be some good deals on e-bay for used tools. Wheels bearings 50 ft. lbs. & 150 ft. lbs. Drive flanges 85 ft. lbs. Lug nuts 350 ft. lbs. (torque stick could work for this too).
Are there any torques much higher than 600 ft. lbs. that anyone knows of? It's not hard to find a ratcheting, click type torque wrench of 100 to 600 ft. lbs.
Just collecting my thoughts in advance of the coming project. Most engine stuff is less that 100 ft. lbs.
Thanks for your thoughts,
Jim
Jim
