source on mep 003 control panel
yellowlister
granada hills ca
There is a mep 003 for sale locally.. missing the complete rear panel with all the gauges and etc.. wires cut.. anyone have a source for a reasonable priced replacement? or maybe I should just pass on it.. as there might of been a reason it was stolen from the gen.. the price is very fair.. but I don't want to spend 1000 piecing parts for it..
Triple Jim
277
North Carolina
That's a whole lot of wiring to try to redo. I think I'd see if someone has a complete control cabinet and just swap them if you end up buying it. You should be able to do a few things like a compression test though. Just jump power to the starter solenoid to crank it. I suppose checking out the injection pump first would be wise, in case it's stuck. Otherwise you'd break things.
