Sourcing Injectors
Hasdrubal
Vancouver BC
Been noticing a drop in mileage lately. Starts, idles and runs great. M1009 has 154,000 miles that I know of. Don't know the history of motor. Got it with 67,000 miles, whether its original IP and injectors or if odometer has gone over once is unknown. Considering getting a set of injectors to see if this is the cause and because I'm told its about time as they wear and it could cause serious engine damage.
So being up here in the Socialist republic of Canada, everything is well over twice the price. No one has injectors, they want me to take mine in for rebuilding and wait a couple of days. Since I buy everything from the great land down south. I would like to buy a set of injectors so that I can swap them in right away. I would like to avoid companies that have a core-charge due to the shipping. I've read through the relevant threads but thought I would throw this info out there for any input. I'm not looking for the cheapest price but dont want to splurge $500 if I can get a good proper set for half that.
One thread here mentioned Pensacola diesel; new injectors $189 no brand mentioned. no core charge. Here's the others I've found ; Accurate diesel ; remanufacured $170. but has a core charge-$80. / Badger diesel; rebuilt with bosch nozzles $145 has core charge-$96. / Mylex international; remanufacured with Italian nozzles(in their opininion atomize better than the OEM nozzles). $176. no core charge. / Found a seller on e-bay with brand new Delphi injectors $160. no core charge # 6704001 MILITARY NSN 2910-01-150-0950 I think these are OEM. So if you're knowlegeable on this matter, pipe up. Let me know what you think or if you have other sources.
Is there a difference between C-code and J-code nozzles. Do these companies that remanufacture pop test them. Is the minimum pressure 1500psi. If I buy the brand new Delphis does this mean I can just install them withought worrying if a rebuilder has been thorough and correct. There aren't any diesel shops around me so I would like to avoid having to find someone to test them.
I know I need new copper washers and probably a good idea to get a new return line kit. Badger diesel has German made braided line that requires no clamps. As well I'll need the 30mm injector socket, found a OTC 5060 Detroit Diesel Injector Socket for $39.00, does that sound about right price wise.
Flingarrows
N Central Illinois
I bought rebuilt injectors from Pensecola. I had one that had a small leak where the body is pressed together after a month or two. They replaced it promptly, no questions asked. They have good customer service.
Warthog
232
OKC, OK
I have a dead engine that you can have the injectors for cores.
Hasdrubal
Vancouver BC
Thanks for the offer, mate. Very much appreciated. I'm leaning towards the brand new OEM Delphis or the remanufactured Mylex's with Italian injectors, neither of which has a core charge. Going to shoot Mylex an e-mail inquiring about what make those Italian injectors are and if they're pop tested to specs.
Warthog
232
OKC, OK
Ranchhopper has a set of new injectors in the classifieds. Very cheap.
DXTAC
Plainfield, Illinois
Flingarrows - The injectors exchange cost me $371.92 total. I have a friend that owns a shop and I received his pricing. I think the regular retail would have been $437.52 or so. The install kit, which you will need, is $39.54.
Hope this helps!!
Hasdrubal
Vancouver BC
Never looked at the classifieds. Checked out Ranchhoppers injectors but they are part #6703802 which shows its for 6.5. The correct injector for a long body fine thread 6.2 is #6704001.
Whats the procedure regarding the getting the fuel lines out of the way, when swapping out a set of injectors?
