Spare tire mount on 105.
1,808
A word of caution to all you folks considering this idea. Make sure you have a trailer with crank up landing gear. The weight of the tire combined with the weight of the nose of the trailer make hand lifting all but impossible. At least now I know why I saved all those spare tire mounts.
Nick
Near Daytona Beach, Florida
What kind of spare mounts? The same ones as shown? Would you be willing to part with one? I'd like to have a spare for mine, even though I'll have a spare on the Power Wagon, a second spare woudl be cool.
I wanted to put it on the front, but the brake handles are in the way. I like the underneath thing, I think I'd see about doing it from the back though
Nick
2Deuces wild
calif
Came from a deuce, He mounted it between the body mounts that bolt the body to the frame. In this spot its at the boxed part of the frame rail. It does not interferer with the brake hands, Air tank or tire. He had to grind a little of the weld from the upper right corner of the M35 tire mount so that it would fit nice and snug. One hole was already there so he just drilled it all the way though.
1,808
Nick
I have the same ones. I need to go out and see how many I have. I have 2 M015 trlrs and plan a spare for each, after that I'll sell em. Matt in Live Oak (Green Gem) probably has a bunch as well..
rosco
30
Delta Junction, Alaska
I'm real sure that I would want to have at least four bolts, holding that thing on. There is a reason for having four, when it goes bouncing down the road empty.
Lee in Alaska
swbradley1
Modertator
1,705
Dayton, OH
I'm not sure it would work under an M101 but I just sold a 101 that had the carrier on the drivers side of the trailer.
(Up on the outside edge that is...)
slotman
29 palms ca
this might also work on the bottom back of a deuce bed for larger super single tires and free up the front for an extra fuel tank and still carry a spare with out taking up space in the bed? will have to go out and take some measurements to see what might be in the way.
Nick
Do you have any pictures of that? Or info on what kind of crrier it was? Just out of curiosity, why wouldnt an under one work?
I have the bows and a cover, so I was thinking a side one wouldnt work to well with the cover. I'd really be interested if someone had pictures of that.
Just trying to get some ideas.
Nick
Nonotagain
41
Parkville, MD
Nick
The M101 trailers tilt the bed from the frame? The tire would be in the way of the tilt if mounted under the bed.
Nick
yeah, mine does have that ability, but i am not gonna do that yet. the a frame where it meets the frame is too tight, I'd hafta heat it and bend it some.
I also have non stock lights on the back and the lights would hit the ground if I tilted the bed, so for now Im not planning on doing that.
If the tire were in the back, but kinda up towards the axle, would it still be in the way? It would hafta be in front of the rear stabilizer leg anyway. Im just not sure about the look of it the way dueces did it..
If not underneath it, the only other way I would wanna do it is on the side.
Nick
Nick
theres an m32a2 spare tire winch on ebay right now. looks like the same one deuces used.
Im just thinking more of the on the side mount, kinda like an m37 style. what kinda mount would work for a 101?
