spark plug replacement
JGBallew
Paducah, Kentucky
It is a RF shielded plug. The "waterproofing" comes from a silicone/rubber finger that goes inside the ceramic insulator, in the steel barrel. (think of the opposite of a "normal" spark plug).
AlfaHeaven carries the correct AC shielded plug for 12.00 each. So you might want to pull yours and clean and gap them.
Unless you drop one, they are very durable.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
You need to verify that they haven't been converted to a civilian ignition. If the spark plug wires screw on to the plug it's still military.
m1010plowboy
2,679
Edmonton, Canada
G749 302 Spark Plugs
Did this get solved Jack?
My local part store brought mine in after a quick cross-reference to LEVI number ### 7524258......but I need to confirm.....
Let me know if it's not solved and I will look up the "NEW"
number.:smile:
