Special Tool Needed?
Lawrence of Arabia
Howell MI
I will be putting the heads back on my Multi-Fuel soon and I am stumped on how to toque the drivers side head bolts/Nuts. I had to heat and bend a 7/8s wrench to get them off, as I could not get a socket to fit in between the head and nut. I am guessing maybe a Crows Foot? Anyone know the trick?
baxter
salt lake, UT
I used a snap on 7/8 o2 sensor wrench similar to a crows foot but closed end put it on an extension and recalculate the torque for the longer wrench.
saddamsnightmare
80
Abilene, Texas
Head Bolts on deuce
January 24th, 2010.
bickdbinkl:
Uncle had a special set of wrenches for the M35A2 series multifuel engines that were designed expressly to work around the obstructions(injectors and such) on the top of the engine. I'd suggest either checking with Steel Soldiers or MV club members in your area to see if you can borrow a set, otherwise check with White Owl, Desert Deuce, et al to see if you can acquire a set. I know they are listed in the 34 P Parts and special tools manual, I just can't seem to dig the number outta the old noggin this afternoon.....
I'm pretty sure one of our giants will chime in, otherwise contact WillWagner on here as he is the absolute wizard of the deuces.....
Cheers,
Kyle F. McGrogan:sad:
