Speddmon's 003 oil filter adaptor
dirtyfingernails
Gainesville, FL
Got my oil filter adaptor from Tom (Speddmon) and installed it today. It only took about 9 days to get it. I changed the oil in my genset this afternoon and installed the adaptor in about 3 minutes! Genset ran like a top as usual. This setup should make for easy oil changes! Thanks much Tom!
Steve
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Steve, I'm glad that you like it and I am also happy to hear that it was as easy for you to install as it was for me.
Speddmon
Cambridge, Ohio
Greg,
No, I drew it up in my free time from being laid off. And then searched for about 2 months for a machine shop close to home here that could program it into a CNC and still keep the cost (raw part cost) under $150 so they would be practical to buy and use. Most of the machine shops I talked to wanted around $150 each or more, and that was if I ordered quantities of 20 and 30 at a time. I finally found a shop, a small mom and pop shop that does great work, that allows me to order them on an as needed basis and doesn't charge an arm and a leg to make them.
