blainedawson
- 0
- 0
- Durango/CO
Can someone explain to me how to remove the speed governor on my m35?
And let us know how it goes!Or you could explore the limit of the existing parts.
I'm going to put in myCan someone explain to me how to remove the speed governor on my m35?
well said but more important whats that in your pic and why dont I have one yetGov adjustment is explained on page 32 of the LDS 465-1 Troubleshooting Manual.
http://old.steelsoldiers.com/index.php?module=pagesetter&tid=1&page=2
This engine is similar to the LDT and LD found in many M35s. Max no-load engine speed is 2850-2900rpm. Max operating speed is 2600rpm. Max torque is at 1800rpm.
As engine speed increases the stress on the connecting rod increase at an exponential rate. When the stress it too great the rod or rod bolts break and you have a mess. There is some extra rpm capacity. It is used for a safety factor. Safety factors are so you don't throw a rod every time you drive it. They are also so the rod can survive a billion operating cycles, and the inadvertent "Opps, I went to 3000rpm"event.
The main point here is rod stress increases -very- fast, you don't how much more it will take, and you don't know what it had to tolerate before you got it. Higher RPM tends to shorten life span exponentially. Power output drops off, wear and noise increase. Fuel efficiency drops (see chart page viii).
The rods hard life is reversing direction at TDC because the metal is in tension. Stress from power and reversing at BDC is much easier to take because the metal is strong under compression. Rod bolts are often the weak link. Sometimes an engine's connecting rod big end distorts at high RPM and turns the rod bearing into a oil wiper. Distortion of .001-.002" is all it takes.
You may be able to operate additional (aka excessive) rpm but I don't recommend it. I prefer to run below 2500rpm . Bigger tires , as already stated, are an option. Member M35-Tom was working on a low ratio gear set for the transmission. Replacing the engine with a radically different design, one with a higher operating range is another solution. You could upgrade items (like custom rods, light pistons, stronger valve train) and build your own high rpm version...
