Speedo bounce
Jones
Sacramento, California
Most often it's a dry cable. Remove the cable(s) and pull them through a gob of grease held in your hand. Better by far than trying to dribble oil down the cable housings.
While you have the cable out you can eyeball it for frayed spots; if any are found replace the cable or it may lock itself in when it unravels... then you get to buy a new cable AND housing.
rsh253
Fort Mill, South Carolina
:ditto:
I had the same speedo needle bounce and now it is nice & steady. I wasn't able to remove my cable from the housing and so I used spray teflon lubricant. I left the housing in place and disconnect both ends and then just keep spraying lubricant through the speedo end until it began to drip out the tranny end. I did this through a day or so and a lot of old grease & cr_p got flushed out. I would have preferred to remove & grease the cable, but this seems to have worked. I plan to re-lubricate every year or so.
-Russ
