Speedo Cable Lube
ssdvc
639
CT
I took my dash apart to clean, repaint, polish, lube and relamp with LED's. I am putting it back together and I just wondered if there was any lube required for the speedo cable. I am lubing up all cables and slide pieces under the dash (where needed) and thought I'd ask before proceeding further.
WWRD99
1,647
York Pa
Up in the speedo head itself I have used dusty graphite puff stuff that doesn't gum up the mechanism inside...it only takes a little bit and it should run smooth for a long time.
