Banshee365
- 14
- 0
- Ocala, FL
Speedo hasn't worked in years according to the mileage on an oil change sticker dated year 2000 exactly 3k miles over the mileage read off the speedo. So today I decided to troubleshoot the problem. I was suspecting a broken speedo cable or gauge itself. You can spin the coupler on the back of the gauge and the needle show's speed, doesn't take alot of RPM to get speed out of it. I easily got 30 mph spinning it with my hand. Here's the weird thing. Disconnected the cable from the back of the panel and held it in my hand while I drove, of course the cable was not spinning, so then I suspected the cable to be at fault. I then removed the cable from the truck. When I had it all out I spun one end and the other spun as well. The connection seemed tight enough on both ends but there wasn't much torque on them. Is it common for problems with the piece coming off of the gearbox that the cable connects to or is that pretty unheard of? Here is a pic of boths ends of the cable where the gauge end is square and the gearbox end has a keyed round shaft. On the gearbox end, it's not have to push the cable far enough down in the cable housing that you have to get some pliers to pull it out. Anything seem out of order here, any ideas? Thanks loads guys!
-Kelly
-Kelly
