Speedo Gear my CUCV
96
17
Lees Summit, Missouri
The small plastic gear in the speedo drive gave out and I have been unable to find a replacement. it looks like it is a 41 tooth gear that fits into the back of the transfer case. Any help? Thanks in advance
Tom Lovinggood
Sharecropper
1,239
Paris KY
You should know that there are several different gears for the NP208, based on factors such as transmission, gear ratio, etc. I recommend you spend a few minutes to familiarize yourself with the different gears. The gear that is in the housing is called the Drive Gear. There is another gear that is on a shaft in the transfer case called the Driven Gear. All of them are on Fleabay. Here's a couple links to get you going -
http://www.73-87.com/7387garage/drivetrain/speedo.htm
