Asmoday
- 0
- 16
- Los Angeles, CA
Hello all...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I decided to replace the speedometer cable and housing this weekend after living with the tick, tick, tick and bounce, bounce, bounce in the speedometer since I bought the M1009 last year.
After removing the old cable and housing I noticed that even though I was supposed to have purchased the correct replacement NOS cable and housing, the new one was shorter. I would say that it was about a foot shorter give or take a few inches.
I decided to go ahead and see if it would install correctly and even though it was shorter I was able to install it and route it the same way as the original cable with the exception that I since I did not have the extra length as the original, I was not able to use one of the clamps that holds it in position under the drivers side floor. The new cable still appears to have correct slack though and none of the bend radius's are very sharp. The new cable was also properly lubricated before the install.
So after the install I take the truck for a drive and the speedo is nice and smooth....no bounce, no noisy tick and everything looks good...............until.................I get to 45mph and then, as if you flip a switch, the speedo needle with spin clockwise all the way to the bottom and swing back and forth over the odometer area. It also makes a bad grinding and whining noise once this happens. I thought the speedo was going to grenade for sure.
When I slow down and come to a stop, the speedo behaves normally after my speed decreases below 40mph and I come to a stop. From a stop the speedo will work correctly until I hit 45mph and then wham o....again it will do what was described above.
After it did this this morning on the way to work....I pulled over after the third time disconnected the cable from the back of the speedo.
So...any ideas what's up? Could it be that the speedo does not like the shorter cable even though it appears to fit well and there are no bad radius turns?
With the original cable and housing the speedo would tick and bounce at low speeds but by 45 to 50mph it would smooth out. The tick would get much worse in warm weather.
A local speedometer shop said it sounds like a bad cable still that's maybe to tight or possibly the speedo has a problem as well although it seemed to work correctly before the cable swap.
So....any ideas...?
Thanks in advance for your help...!
So....any ideas...?
