speedometer cable help
bigswin
Indianapolis, IN
Hey guys, last week I switched out my glowplugs got the truck squared away and put back together. Now, the speedo doesn't work. Everything else on the dash in operational so I figure I must have done something to the cable while I was climbing around in the engine bay or from when i was on the creeper. Can someone tell me what the cable looks like and where it is so I can run it down? Thanks!!!
4bogginchevys
rathdrum idaho
cable runs from rear pass side of transfer, across top of tranfer/trans...along by the shifter linkage....up the fire wall and in to a grommet, then strait into the back of the cluster. It should have a clip hootice holding it to the firewall roughly underneath the brake fluid resivoir.
