Speedometer Jumping Around at 40 MPH Only
70deuce
121
Franktown, CO
Heath_h49008 good point. As the truck is driven around here, most of the time its below or above that speed but annoying none the less. I would agree though its probaly gearing within the speedo itself. I will take your advise and swap another one in to see if it changes the gripe. Changing the cable is a pain in the butt but just swapping a speedometer not so much.
rosco
30
Delta Junction, Alaska
Its usually always the cable. Before you replace anything, disconnect one end or the other, and pull the inside cable out. Clean it with Break Clean & a rag/paper towels. Re-insert it and as you slide it back in, re-grease it with a good light weight grease. Note: sometimes you can only pull them from one end or the other, & I don't remember which end. So I think you pull it from the top - not sure though. Too simple, not to try. But usually the bounce is the cable.......
