- 323
- 5
- 18
- North Dallas, TX
Anyone know if there is a way to recalibrate the speedometer for larger tires?
Forgive me cause I dont know what a M34 is, but does it have the same gear ratio in the axles as a m35 because that would affect the speedo to.you can get a speedo adapter from a m34 but they are hard to find that would put your speedo right since they had 11.oos on em stock
Double check the NSNs, the 5-tonners have different axle ratios.
