TM1008
- 0
- 1
- Kassel / Germany
Hello everybody
I need some help.
On my M1008 I have now mounted 315 75 r16 tires and now the speedometer is no longer showing the correct speed.
On NP208 is installed a pinion with 44 teeth, color gray.
On the case are the numbers 40/41/42/43.
I would like to order from TCI Auto a suitable pinion (i found some at Summit Racing), but I do not know which one to take.
I assume that nothing was changed on the car.
When I bought it, there were 285 75 r16 tires installed.
Before changing to the 315 I had the original tires mounted, 235 85 r16.
maybe someone has an idea or a solution
thanks in advance...
Greetings from Germany
I need some help.
