- 2,666
- 6,216
- 113
- West greenwich/RI
Hello folks, I wanted to ask the Deuce community for a little input regarding spin on filter bases that I make for the MEP-002 thru 005 generators.
A fellow S.S member asked if I had checked to see if the same canister base ( which my adapters replace ) are used on any other military equipment.
Truth is, no I really haven't.
It looks like the M35 may use a similar base but with larger fittings for the inlet and outlet lines.
I was wondering if anyone knows off hand what size the line threads are on these bases?
Also, do you know if the mounting bolts are also 3/8"-18 bolts on a 2" x 2 1/2" pattern?
I was considering making a modified version of the generator filter base, seen here:
With the correct thread sizes for the Deuce.
If the community thinks they would have any use for them?
I see that Jatonka makes an adapter kit already.
This would not be an adapter, but rather a new base that would totally eliminate the original mount base and eliminate all the extra parts and gaskets associated with an adapter.
Your thoughts and comments are welcomed.
Mep-002A 003A 004A 005A Drop in Spin on Fuel filter adapter
Last week I mentioned developing an easy to use spin-on fuel filter adapter for use rather than the the WIX 24470 Here is a look at the first production parts off the CNC machine and mounted on my 002A for your viewing pleasure. These adapters drop right in place of the original Fram canister...
www.steelsoldiers.com
