Spindle bearing?
nspctr1
San Antonio TX
I found the timken bearing numbers for the spindle but it shows 3 bearings. I need the inner and outer one. The numbers I g
Found are below.
Which ones do I need?
LM104949. Or
3780. Or
3490. Should I replace the races too?
Thx
ken
24
Houston Texas
[h=3]Geared Hub Bearings[/h]
  • Outer Bearing Cone Timken 3780
  • Outer Race Cup Timken 3720
  • Inner Bearing Cone Timken 3490
  • Inner Race Cup Timken 3420
  • Upper Bearing Cone LM104949
  • Upper Race Cup LM104911
  • Input top seal 29940-2106 or 5590745
  • Spindle outer seal 29940-2094, or CR535094-60
When replacing a tapered roller bearing ALWAYS replace the race also. When a bearing wears there will be small pits in the race way and rollers. IF you only change the bearing the pits in the old raceway will accelerate the wear on the new rollers.
