Interesting - The diagram shows ONE dual system master cylinder and TWO air-hydraulic booster units! Guess I need to read up more on Deuce brake systems. In most cars/light trucks with vacuum or hydraulic boosters (which is what I am most familiar with), the booster acts on the master cylinder push rod to provide braking assist. It appears that on the Deuce that there is no assist to the master cylinder push rod, when the brake pedal is pushed the m/c forces brake fluid into the AHU and the AHU then magically boosts the hydraulic pressure in the lines going to the wheel cylinders. Do I have basic concept down right?
That would explain why the Deuce split brake system requires two AHUs, one to boost each of the two separate downstream hydraulic systems. With all that out of the way, does anyone have a part number or specific application for the GM Medium Duty Truck master cylinder Marcus mentioned? This sounds like an interesting and worthwhile mod. I like driving my Deuce with six wheel brakes, but in the event a brake hose pops, I'd much rather have three wheels with brakes rather than NO brakes at all (assuming I did the split diagonal mod rather than the OE front/rear version).
