- 8,429
- 2,507
- 113
- Monrovia, Ca.
Hi guys, I tested the deuce yesterday, tried Kennys' trick of using a tree, works great! The rears both spun, the fronts didn't. Did the test in low range, 1st gear, backed up, tried again, no front wheel spin. When I backed up and made a left turn to move away from the tree, the front end acted and felt like when the hubs are locked on my Chevy 1 ton turning on a hard surface, like the fronts were driving. Tried the test again, no front wheel spin. I saerched through posts and came across a link about an M211 front end not pulling. It described an adjustment to a rod at the t-case for the sprague. Does the M35 have this adjustment rod?
