rickycotte
- 0
- 0
- San German, Puerto Rico
Hi everyone, upon searching for some member experiences regarding malfunction of stop brake light switch on M939 series, I stumbled upon a thread having to do with the spring brake operation. Without going any deeper on the reasons for that thread being closed, I just wanted to add/share a resource for those of us in need of constant learning. It is a website from Sealco which is a builder of air brake components where I found great information, very well presented for explaining the different components and their operation.
All of us can use information and almost always something new arises that we did not know. God Bless you all.
http://www.sealcocvp.com/
Another useful resource:
http://www.lowestpricetrafficschool.com/handbooks/cdl/en/5/1
[h=3]5.1.14 - Spring Brakes[/h]All trucks, truck tractors, and buses must be equipped with emergency brakes and parking brakes. They must be held on by mechanical force (because air pressure can eventually leak away). Spring brakes are usually used to meet these needs. When driving, powerful springs are held back by air pressure. If the air pressure is removed, the springs put on the brakes. A parking brake control in the cab allows the driver to let the air out of the spring brakes. This lets the springs put the brakes on. A leak in the air brake system, which causes all the air to be lost, will also cause the springs to put on the brakes.
Tractor and straight truck spring brakes will come fully on when air pressure drops to a range of 20 to 45 psi (typically 20 to 30 psi). Do not wait for the brakes to come on automatically. When the low air pressure warning light and buzzer first come on, bring the vehicle to a safe stop right away, while you can still control the brakes.
The braking power of spring brakes depends on the brakes being in adjustment. If the brakes are not adjusted properly, neither the regular brakes nor the emergency/parking brakes will work right.
[h=3]5.1.15 - Parking Brake Controls[/h]
Figure 5-3In newer vehicles with air brakes, you put on the parking brakes using a diamond-shaped, yellow, push-pull control knob. You pull the knob out to put the parking brakes (spring brakes) on, and push it in to release them. On older vehicles, the parking brakes may be controlled by a lever. Use the parking brakes whenever you park.
Caution.Never push the brake pedal down when the spring brakes are on. If you do, the brakes could be damaged by the combined forces of the springs and the air pressure. Many brake systems are designed so this will not happen. But not all systems are set up that way, and those that are may not always work. It is much better to develop the habit of not pushing the brake pedal down when the spring brakes are on.
![](http://cdn.nationalsafetycommission.com/handbooks/images/7/fig5-3.gif)
Figure 5-3
