Spring Measurements
comdiver
Buffalo NY
I'm doing a little armchair engineering and need a hand. Is anyone near their deuce? I need a few measurements. How wide are the front springs? What is the unloaded distance between the bottom of the frame and the top of the rear axle? What is the size of the axle tube, width and height, near the springs? Thank you.
mucekok
spring, tx
front spring width 2.75"
outside to outside of front springs 33.75"
bottom of frame to top of rear axle 11.25"
axle tube dim. 3.5"x3.5"
hope this helps
