Spring perches on a bobbed 5 ton using deuce springs
dilligaf13
34
south, florida
I'm using M35 front springs to bob an old M813. My question is, what do you do for spring perches?
The M35 spring perch obviously isn't big enough to fit on the 5 ton axle so I'm thinking of using 5 ton perches but then I run into the issue that the M35 spring is 2.5" whereas the 5 ton spring is 3" wide. Thoughts?? Thanks.
bsome12
Utah
I'm not sure how others have done this but in the world of off-roading, it is common to remove spring perches and move or replace them. If it were my project, I would probably be lazy and find a way to use the 3" perches as they sit. Can you drill or grind the existing 3" perches so that your 2.5" "U" bolts will fit?
