Spring Seat Question
Tinwoodsman
75
Comfort, Texas
:?: I am starting on the refurb of my driver seat and want to take it apart, blast it and repaint it. I am doing my interior in Rapco Semi-Gloss Olive Drab. In looking at the construction and springs, it seems like it could be a real nightmare trying to get it back together once the parts are refinished. Anyone done this before and have any advice.
M35A2-AZ
376
Tonopah, AZ
Tinwoodsman, I am doing the same thing to my Deuce. I am going to use the
Semi-Gloss Olive Drab also.
I look at the seat and I think I am going to just try to paint it all together.
Good luck with your repaint job!!![thumbzup]
Tinwoodsman
75
Comfort, Texas
Thanks for the recommendations and suggestion to clean and paint. I wish that were true. Mine looks like a depository for excess CARC paint. Hopefully someone will have disassembly and assembly experience so I can thoroughly clean this puppy.
rrrr
Missouri
I am doing the same thing. Took the cushions off and the hit it with a wire wheel on my air tools. Helped a lot. Some areas I couldn't reach so cleaned up the best I could and painted over. I'm using flat OD for my interior and will desert tan the outside again when the cab is complete.
gringeltaube
Staff Member
2,371
Montevideo/Uruguay
............ In looking at the construction and springs, it seems like it could be a real nightmare trying to get it back together once the parts are refinished. Anyone done this before and have any advice.
Come on Kent, anyone capable of refurbishing his front winch should be able also to do that seat - blindfolded...:p
Don't leave things half-done! Sure enough you'll find some surface rust already present where it never saw any fresh paint. Also cleaning and re-lubricating the adjuster threaded rod plus all bushings will give you peace (of mind) :)
It really isn't complicated at all; no way to end with parts upside-down. Take a few pics just in case and look at the diagram below..... Or post more Qs....:mrgreen:
G.
Tinwoodsman
75
Comfort, Texas
That does it G. You have laid down the gauntlet. The only thing I do not see your attachment is the coil spring controlled by the adjusting arm. Either way, this puppy is coming apart and you come visit me in Texas if I get stumped. :-D
KsM715
142
St George Ks
Ive pulled one apart to clean it up after getting it out of a salvage yard. Its really not that hard. I dont remember any steps. All I remember is the hardest part was getting the last few bolts back into #27 while holding the seat down under tension from the spring.
#27 is in reference to the diagram posted by gringletaube
Tinwoodsman
75
Comfort, Texas
Thanks for the tip WM. I have already purchased a set of covers from Jatonka but will keep that in mind. Here is my companion seat I already did. Say hi to Elmo.
Tinwoodsman
75
Comfort, Texas
Well, with G's. encouragement, I tackled the driver's seat and here is the result. Strangely enough, taking it apart was harder than reassembly due to the rust and mis-matched hardware. After a full cleaning, primer and paint I re-assembled the seat and re-upholstered the cushions (wrinkles still need to smooth out) and here it is. I feel so much better now. :)
Tinwoodsman
75
Comfort, Texas
The seat back has a curved arm that moves against the back of my seat which is a solid metal pan. Moving the lever raise the back up and down. If you have something different, I would like to see a picture.
goldwing2000
Banned
506
15
Ingham County, Michigan
All three of my spring seats have an additional thin metal plate on the outside of the upholstery that the curved bar sits against (to keep the fabric from wearing through, I'm assuming). If nobody else comes up with a pic, I'll try to get you one tomorrow (as it's dark now).
