Squeaky belt
Coug
4,241
Olympia/WA
Mine squeaked when my belt was out of alignment.
Alternator bracket had the rear brace stud on the exhaust sheared off, and that put extra stress on the front bolts, two of which sheared off and the third loosened. Ended up replacing the rear bracket with the newer one.
If your serial number is below 196900 (the power steering reservoir is on the pump and not remoted to the top of the engine) you might check to see if the alternator is loose.
If your serial number is above that, then just check to make sure everything is lined up properly.
Doug D.
27
Winterville Ga
yea my reservoir is on top. i will check everything. So if everything is aligned and tight---would you use belt dressing?
juanprado
2,866
Metairie/La (N'awlins)
Yes but it is masking the real problem probably. The rubber is older and deteriorating. The belt dressing is lubricating & softening the rubber and buying you time. I would recommend non military belts from your neighborhood parts store preferably a name brand like Dayco, Gates, Goodyear etc. No telling how long military belts were made or in storage before being surplussed......
Mogman
9,146
Papalote, TX
i have a M1114 humvee and the belts squeak when i push the accelerator. Any ideas on what to do?
If a serpentine belt is squealing there is something wrong, if it is squealing when the engine is revved up I would check to make sure it has enough tension, look at the pulley alignment closely, as mentioned before all new HMMWV owners should check all the alt. mounting bolts as that is a VERY common issue.
Replacing the belt and all the idler pulleys is cheap insurance and you can inspect things better as you do this.
Also with the serpentine belt setup you do not have to mess with the fan clutch hose etc. to replace the belt.
Coug
4,241
Olympia/WA
The idler pulleys use a replaceable bearing in them that isn't that hard to change out. If nothing else keep a few of them on hand.
6203 bearings, 2 per idler.
Maxjeep1
1,912
Las Vegas Nevada
Mine didn’t squeak and it started after a few hundred miles and it drove me nuts! Ordered a new belt from Mac Motors I believe and it wasn’t a cogged belt like the original. It was fine for a few hundred miles and it started squeaking. I replaced it with a gates fleet belt that was green and I have 1,900 squeak free miles. I can’t explain why it was doing it and I checked alignment and spun pulleys. Change your belt and see what happens
Doug D.
27
Winterville Ga
thanks--you have any part numbers for those non-military belts?
Adrok
182
33
Rochester NY
Check and investigate for underlying problems: Alignment, age, damage, tension. If all is good, then it should not 'squeak' consistently. If the noise is intermittent ( start up, rain ) then you might consider moisture / humidity / contamination. At that point keep driving or replace with a modern non-mil belt.
Doug D.
27
Winterville Ga
thanks and will do!
juanprado
2,866
I assume you have the 6.2/6.5 with v belts? check this thread for belt numbers and matched set information if not familiar with the term:
Doug D.
27
Winterville Ga
no its serpentine belt with A/C COMPRESSOR
juanprado
2,866
Mine is older M998 so I am not familiar with the serpentine belt set ups but there are many posts on here with the information depending on serial number, ac, and turbo from what I recall. Use your friend google but verify :cool:
juanprado
2,866
so in another lifetime I sold parts. We had a simple way to help people determine if the belt or component was the issue. Use a plain ole bar of soap and let it rub while the belt is moving. If the noise goes away, belt is bad. Soap wont cure a bad pulley bearing, tensioner etc....
TOBASH
3,364
Brooklyn, NY
Excellent idea. Maybe the less mechanically inclined should use a pliers to hold the soap near the belt, or else count fingers before and after the test and them compare the numbers…
Seriously, awesome method to check belt.
