- 305
- 395
- 63
- Geographical Center of Virginia
I'm stuck and don't know what to do. Here's what happened
M1009 Cucv Blazer, still 24v, glow plugs are not bypassed.
-Originally had no alternators when I bought the vehicle, bought two of them off Ebay. Both isolated ground 100ish amp alternators. All new gates belts.
-Driver side worked fine, passenger side started to squeal after about 1.5 hours of use. Sent back the alternator and received a rebuilt alternator.
-Installed the new alternator and started the cucv last night for around 1 minute, no squeal, putting out proper voltage.
-Started the vehicle today and it squeals as bad as the one i sent back in originally. I recieved a completely different alternator. This appears to be a decent quality delco-Remy unit.
Only difference between today and yesterday is that I ran down the batteries a bit while I was fixing all the vehicle lights.
The belt is tight, I tried it at varying tightness with the same result. The vehicle is still 24v. The pulley is too hot to hold your hand on.
What should I do next? New alternator? New belt? I do not have the time to send in this unit for a replacement.
