Stanadyne DB2831-6282 IP pump- what's it used on?
LCA078
112
Austin, TX
This IP came in a 'gov box o'stuff' so no idea if it's even good but at least I'd like to know what it's used on. Random bits of info on the interwebs says it's a direct replacement for the DB2831-5079 which is the 6.5L Turbo version but the -6282 isn't listed in the usual Stanadyne docs floating around.
Any one have definitive info on use for the -6282?
Mogman
10,576
Papalote, TX
sbgarage
50
Wv
I can give it a good home if it's looking for one :LOL:
In all seriousness though, that's a good unit you have well worth a rebuild if it isn't in working order
LCA078
112
Austin, TX
Thanks Mogman. I did see info it the 6.5L turbo but had no idea if it was a civilian only or industrial version or such that wouldn't fit on a green machine. I'm guessing from your posts this is a direct fit for a mil 6.5L turbo...
But to SB's point, it does look in good shape and doesn't look to have been installed. It even has the red plastic protectors on the outlets so there's a chance it's a NOS item that for some reason was put in the 'box o' stuff' for auction. Maybe because the pn wasn't listed in any of the standard mil documentation, someone decided not to risk it and "tossed" it.
Since I don't have a turbo HMMWV (yet), I'll let it sit on the shelf. I vaguely remember reading somewhere here that at turbo IP could be used on a 6.5L NA but I'll have to chase down that info.
