Skinny
- 488
- 83
- Portsmouth, NH
My box filter was working fine but I had some small drips from the water drain, the water in fuel sensor lost its mind, and in general I dispise its very existance. While I had the fuel system torn down doing a new injection pump, I seized this moment to upgrade the filter system to protect my new $500 investment.
I ordered the FM100 filter head with 3/8" NPT fittings from the DieselStore. I also got a 6" long 2 micron filter along with the highest output 24v heater. When I add a another saddle tank and 6 port selector valve, I will add another FM100 150 or 30 micron filter back by the SECM box. For now it will just be the 2 micron.
The bolt holes for the original bracket line right up but the filter hits the wiring underneath it. I added a 3/4" spacer made of some high density plastic that I "borrowed" from the machine shop. Just as a reference to people searching, the inlet that comes from the fuel pump is 3/8" ID line and the outlet going to the IP is 1/4" ID line. I used 90 degree elbows to keep things tidy.
I went with single crimp stainless clamps on all my connections. Yes, you have to cut them to remove them but that is the great thing. I shouldn't have to remove or keep retightening them. All parts purchased through McMaster Carr. Click...add to cart...shows up in 3 days.
For the heater, I automatically assumed the stock heater was 24v but it is 12v. Woops! I used the stock heater pigtail to trigger a relay which I pulled a feed off of the 24v bus bar with an inline fuse. Should have no gel issue up here in Maine...yes sah
I went with the Stanadyne setup because it is about half of what a Raycor would go for. I just helped my buddy put a Racor in his sail boat and I was not pleased with the quality versus cost. I believe the words I used were, "this thing sucks." It leaked fuel right off the bat from the fuel drain and the filter could not be removed by hand because the robot puts them on too tight from the factory. Not cool for $250. My setup was no more than $150 out the door with all my fittings and accessories.
