Standard Trailer on a M932A2 Tractor
BMY Tractor
Black Forest Colorado
I am brand new to Steel Soldiers, have just bought a BMY M932A2 tractor, the question I have is can it be coupled to a standard semi trailer? I know about the 24 volt to 12 volt problem ( I'll change the lamps in the trailer). Of course the trailer I bought has air brakes. I have been told that the 5th wheel on the tractor might not mate to the king pin on the trailer, This is not a box trailer, but an old school equipment trailer, where a goose neck goes up and over the 5th wheel, with a lower deck and a dove tail with ramps.
Will I have to change out the 5th wheel to make this work?
Jbulach
2,127
Sunman Indiana
No.
Biggest problem is typically hight. If your trailer has a mechanical detach neck with frame rollers on the front, you will need to ramp the back of the truck. Also the neck ot your trailer may not be long enough to clear the tires while turning.
simp5782
Feo, Fuerte y Formal
9,317
Mason, TN
Just go to your local truck parts place and get 24v LEDs. And wire them in according. I run a standard 4 flat trailer plug that i have scotch locked into my harness at the tail lamps then ran the trailer wires.
Sent from my SM-G860P using Tapatalk
M813rc
2,842
Near Austin, Texas
The 931 has a standard 2" plate on it. It will hook to civilian trailers. The 931 generates enough air to run the brakes on the trailer.
On one of my 931s, I replaced the military two-axis tilt 5th wheel with a Fontaine slider off a civilian truck. The frame width is the same between the civvy and military trucks (in this case), so it was a bolt on change, though I did have to drill some extra holes.
The net result is that it lowered the plate height by almost 8", which is good for when you haul a box trailer,. It also allows the 5th wheel to slide further to the rear to clear the fat tail end of the A2 when hauling short-necked trailers like the M146. Most equipment trailers have a long enough neck to clear the tires, but sometimes you need just a couple more inches of clearance.
Cheers
Jbulach
2,127
Sunman Indiana
Also don't forget, if you change to a lower civilian fifth wheel, especially if pulling a van off road, you might want to lower your bumpstops on your axles just a bit as well, to keep the tires from getting into the underside of your trailer during articulation.
