- 850
- 1,689
- 93
- Wauchula, FL
Check your starter bolts regularly. I was working on mine today and noticed a small gap between the starter and the housing mounting surface. The starter was very loose and missing two of the 3 bolts holding it onto the housing. I cant believe it was still starting ok.
I also discovered the starter has an adapter plate mounted to the starter with 5 or 6 metric socket head cap screws that were also loose.
The missing bolts are 12-point flange head cap screws M10-1.5x35mm.
Cat PN# 108-7808 Black oxide
Cat PN# 118-9573 Zink
![91271a624p1-b01s.png 91271a624p1-b01s.png](https://www.steelsoldiers.com/data/attachments/425/425515-bdc0b94166e55990cedf00f21d51552e.jpg)
