Starter Connections
SpoiledSpud
Northern (ID/WI)
My SEE arrived a couple weeks ago with a starting issue. The previous owner was kind enough to remove the starter prior shipping, which did have issues and has since been rebuilt. So far I haven't found a clear diagram of which starter connections go where. My harness appears to have the original numbered conductors. If anyone can help clarify I would appreciate it.
Thanks,
Spud
SpoiledSpud
Northern (ID/WI)
And, as a bonus question to my Starter experts out there, do I even have the correct starter? The Bosch part number stamped into the case of my starter is 0 001 368 035. From everything I can tell, the original was Bosch part number 0 001 368 028. I've been unable to find any sort of cross reference connecting the numbers.
Guyfang
23,347
Burgkunstadt, Germany
Have you looked at the schematic in the TM forum? There is a wall chart schematic for the CEE. If the wires in your harnes are still numbered, maybe that might work.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I know I haven't worked on any mogs but, can it really be that hard to figure out a +, a -, and a trigger?
I would think it should be fairly simple, is there a bunch of wires not hooked up?
gimpyrobb
27,785
749
Cincy Ohio
Oh wow.
I'd try using a dvm to see if they have continuity to ground, then see if they have continuity back to the battery + terminal. That should get you in the right direction.
Guyfang
23,347
If you cant read this, I can try again.
There are 6 different part numbers for the CEE starter. the 035 number was not one of them. Also 2 canceled NSN's
Guyfang
23,347
I looked back into the TM forum, for CEE TM's. The only thing I found were the wall chart that I posted, and the same wall chart, someone else posted before me. Maybe my old eyes are just bad. I thought there was more. I have all the CEE Tms, but cant upload them due to size. If there is any interest in the TM's, let me know. PM me and we can work something out. I can put the files on a disc, and send them to you. All I want is my postage. There is also an extra handout from TACOM with beginner info on the CEE. Also a complete wall poster schematic like the one already uploaded. Several of the TM's have change 1 and 2 posted in them. I can post a list if anyone is interested in them.
