Starter driving me nuts!!
b framer
Lincoln, Nebraska
I've had my M1028 for four years now and drive it most days to work. It's a great truck...but it seems like every six months the starter gives up the ghost. Luckily the starter is always under warranty so I get another one. My question is has anyone had this same problem and if so what was the permanent fix?
1,808
Lifetime warranty starters guarantee you will be replacing them for a lifetime. Where are you buying these 24V starters?
dependable
188
Tisbury, Massachusetts
If you have an occasional short due to bad insulation on starter cable it can cause starter solenoid failure. Had a starter heat shield that got bent and occasionally shorted main positive cable to starter. Did not know why I was going though solenoids about every 6 months until I noticed sparks by starter when one of the crew started it in the dark hours of winter.
edpdx
75
Oregon
I ordered a Wilson 28MT 24V from Schucks after having bad luck with the $100 *bay Chinese model. Real heavy-duty. Comes with a shim that you should use- don't ask...
Real reliable cranking. See my posts w/ Wilson in the search for the part number.
