Bravo2Uniform
- 21
- 18
- McMinnville, TN
My starter will engage and turn with the ignition switch in the "Off" position. I know this isn't correct, but I'm not sure where to start troubleshooting. This is the ignition switch I am using:
It looks like it is hooked up correctly, the numbers match up, with 85 remaining unattached for as a power shunt for the heater (to be installed later).
I converted over from a 12 volt hack job so I have never started the M38A1 with the 24 volt system.
