Starter MEP 3 issues
panic_button
Emerald Coast, FL
My starter worked flawlessly for the first 2 weeks I had the MEP. After a week sitting and a week of rain I went to fire it up today to add my digital Hz meter, and the starter didn't want to engage the flywheel, just the dreaded spinning sound. After a few attempts it caught but then the solenoid would not release, causing the starter to spin. Turning the switch to off had no effect and pulling the DC breaker did nothing, had to pull the battery cable for it to stop. I tried several more times with the same results. I sprayed it down with PB blast and will let it sit over night and try in the morning to see what happens.
Per TM, Starter is a Type 1, can I use Type 2?
Any thoughts on what else to do? Or just replace the starter?
panic_button
Emerald Coast, FL
After sitting overnight, I fired it up again last night. No problems with the starter and fired up fine. I did notice that the rubber sheet around the acutator is torn, maybe it rusted up and the PB freed it up. I spayed it with white grease so hopefully it will help. I also got a waterproof ATV cover for the set to keep the water off the unit. It fits great and was only $40 from Wally World.
