Starter problem
FreightTrain
Banned
2,730
13
Gadsden,Al
On the weekend from Hades(if you read the story) I killed my starter.I think mud and water got into it cause ever since then the starter has had a dead spot.I hit the button and can hear a click.I can keep hitting it and some times it will finally spin over and start the truck but some times I have to hit it with a hammer.
sermis
17
Temple, TX
Check cables, remove and clean starter to make sure it is grounding good. Last option is tare it down and clean and lube.
cranetruck
75
Meadows of Dan, Virginia
Sounds like the solenoid to me. A disc moves forward slamming against two contacts making the connection. A spring pulls it back. If the disc gets lopsided or burns, you'll have an intermittant connection.
Solution: Replace/rebuild solenoid.
cbvet
20
Northwest (Knox) Indiana
Check the ground & cables. If they are clean & tight, you will have to take it apart & clean it up. Electric motor cleaner & some emery cloth works well. Make sure all internal electrical contact points are clean.
Will probably be OK.
CBVET
Pinkie
hague, va
I am having the same problem. How much does a solenoid go for? Can a solenoid be replaced while the starter is on the engine?
red devils dude
Ft Campbell
jd yes I think you just get it off when the starters on the truck but a new from Leece-Neville solenoid is
.... $350 so generally your better off finding a new starter.
