starter problems
319
Lieutenant
58
Michigan
Also be sure you are using the correct OEM bolts, they're metric. Must buy them from a GM dealer.
91W350
57
Salina, Kansas
On my first one, it kept skipping and had chewed off a few teeth on the flywheel. When I replaced the flywheel, I left the transmission and transfer case on my jack and installed some six inch long bolts to keep it lined up. After swapping the flywheel, it was easy to slide the gearboxes back oin place. Just a tip if you do have to change the flywheel. Glen
