Starter Relay Voltages
mutt1966
13
Allentown, PA
Need some help here what are the voltages I should be seeing at the relay(doghead modification done) when the ignition switch is turned on, I have 25.7V at the RED wire on the relay but only getting around 20.3V at the PURPLE wire when I go to start, it seems a little anemic, is that right or should I be seeing more there. Thanks for any help, Scott O&O
Barrman
1,735
Giddings, Texas
Sounds like your ground wire isn't doing its job or the relay is bad. There should be very little if any voltage loss across the relay.
