starter / smoke/ voltmeter ? help?
CUCV85beast
California
Went to the junkyard and was lucky enough to find a few things I was looking for, get in the truck and it barely starts to turn over when suddenly it stops. I tried to start it again only to see a bunch of smoke coming from the bus bar, a small red wire with a black plastic tube on it numbered 16 was melted and actually split in two.
I clamped the wire back together and tried starting it again only to hear a single click.
The voltmeter also stopped working.
What the **** happened?
1,174
Look at the bottom most fuse in the fuse box. It will be blown.
The fusible link you described, needs to be replaced.
You may need your starter rebuilt.
CUCV85beast
California
The bottom most fuse is fine. The wire labeled 16 is a fusable link?thought it was but I was confused, Is the fuse sealed inside the plastic? Thought I should be able to access said fuse in link...sorry my electrical knowledge is not great.
1,174
Fusible links are not repairable, you replace them.
CUCV85beast
California
Well I got the relays and a new fusible link, this one doesn't have the plastic tube on it tho... I'm assuming I just cut out the plastic from the original and splice this one in between. Hopefully this works.
1,174
Simple answer, they are color coded (your wire is red)
here's a link with good info. Fusible Links
1,174
Replace the whole fusible link, not just the black part. About 6".
CUCV85beast
California
Great, yeah I replaced the relays and the fusible link. Now the gen 2 light and voltmeter are back in action but still not starting. Think I need a new starter.
